Ok thought this migh be the case but its the coolest its been on holiday. Has been much hotter with no problemsI assume it is hot where you are ?
Heat & lack of cooling cause panels to loose efficiency.
How long have you had the system and when last did you properly clean the panel?Ok thought this migh be the case but its the coolest its been on holiday. Has been much hotter with no problems
Cheers WelshGas will try that but do clean it regular plus it was working this morning.How long have you had the system and when last did you properly clean the panel?
I had washed my panel when I washed the car, but didn't polish or dry it as I did the rest of the vehicle and used a wax based car shampoo. When I lost some power I examined it closely and realised it was covered with a yellow tinted build up of traffic film/wax. I gently cleaned it with a mild abrasive that lifted the film, no longer yellow, and polished with a clear polish. Now back to full output 20V or so in full sun.
