NickE
- Messages
- 152
- Vehicle
- T5 SE 180
Well, that's it in a nutshell isn't it? Identical weather conditions, old bellows doesn't leak, new one does.
Someone has previously stated that the “C” isn’t a new version.Bad news guys. Sounds like it backs to the drawing board. The infamous 'C' variant was installed this morning on a German Cali and guess what...... it leaked like a sieve. NO, this is not the much anticipated resolution. VW MY23 customers must suffer a little while longer
Not sure where that came from. My dealer told me the grey bellows now have a new part number.Someone has previously stated that the “C” isn’t a new version.
This was my hypothesis a few pages back. I have a Coast with manual poptop and new MY23 fabric. I did have it open to light wind and steady rain hitting the front pano panel for a couple of hours. No leaks noticed. Personally I think the tensioning could be a contributory factor, although not the only cause. To me it's a combination of the stretchy new material, too much tension, use of synthetic thread (doesn't swell when wet) and lack of a barrier layer.Do you think the preset tension value may be set too high so its stretching the material and causing elongation of the needle holes thus letting in the water? Has anyone with a manual roof with the new style bellows reported it leaking?
The fabric itself is far more water resistant. The old one had a water column rating of 300mm, the new one is 7500mm. Huge difference. The issue is the application of the fabric and seepage through seams.Not sure if it helps but I dried my with cloth and put the roof down when wet to stop it getting horrendous overnight when I wasn’t in it. Next day the bits I dried were still dry. Put the roof up to dry that out and came back later to find the residual water in the canvas had leaked out again inside the van. I do wonder if the fabric itself absorbing rain water is a significant factor. This would explain the delay of about an hour from when rain started hitting my canvas and it started leaking. The canvas became saturated first.
Please can you explain what this means? And why does my canvas retain water if it’s water resistant?The fabric itself is far more water resistant. The old one had a water column rating of 300mm, the new one is 7500mm. Huge difference. The issue is the application of the fabric and seepage through seams.
It's the height of water above the fabric at a point where a few drops start to permeate. It might absorb some water but that does not necessarily mean water seeps through. These fabrics are water resistant not water proof.Please can you explain what this means? And why does my canvas retain water if it’s water resistant?
Mine had this. They replaced the seal at the first service and it’s now sorted.slight leak on the tailgate
170 quid for double mattress topper? Better sing me a lullaby at that price.Mine had this. They replaced the seal at the first service and it’s now sorted.
Vw don’t test or check the campervan “side” of their Cali. The campervan parts are all made by other companies so they rely on their quality testing.I find it unbelievable that a company like VW don’t seem able to carry out a basic quality check on a component part of one of their products, before they sign it off and sell it.
Anyone designing and producing a “tent” might have ”checking for leaks” at the top of the list of checks.m
Ok makes sense. It might be what they claim but I’m not sure I believe it to be true then. My canvas was absolutely saturated externally after 1 hour and remained so until the next day. Felt like water was trapped between the 2 layers.It's the height of water above the fabric at a point where a few drops start to permeate. It might absorb some water but that does not necessarily mean water seeps through. These fabrics are water resistant not water proof.
Any pushback? How many miles on the odo?Not for me, I’ve rejected my 4 week old Cali.
Water trapped is more likely and by folding and unfolding you’ve redistributed it to somewhere it can escape. This then begs the question that those with leaky bellows, does it mean there’s often water trapped between the fabric layers even when the roof appears to be dry?Ok makes sense. It might be what they claim but I’m not sure I believe it to be true then. My canvas was absolutely saturated externally after 1 hour and remained so until the next day. Felt like water was trapped between the 2 layers.
The fabric is bonded so not sure how whats can be trapped 'between' the layers.Water trapped is more likely and by folding and unfolding you’ve redistributed it to somewhere it can escape. This then begs the question that those with leaky bellows, does it mean there’s often water trapped between the fabric layers even when the roof appears to be dry?
The new bellows may well have a new part number, but someone on here has a "C" bellows that leaks & that was reported well before one of the dealers had said that there wasn't a new part number yet.Not sure where that came from. My dealer told me the grey bellows now have a new part number.
Yes it’s a good question. Mine leaks at the bottom so somehow the water has travelled down there.The fabric is bonded so not sure how whats can be trapped 'between' the layers.
Ah got ya. Yes good point. Maybe there is hope! HahaThe new bellows may well have a new part number, but someone on here has a "C" bellows that leaks & that was reported well before one of the dealers had said that there wasn't a new part number yet.
If that’s the case they’re risking their reputation on someone else’s workmanship. VW would have had to set their technical requirements when setting up the contracts with their suppliers and I’d hope in the case of the canvas they’d specify that it was waterproof and have sign off that testing had taken place to check.Vw don’t test o
I’ve just this minute finished my letter rejecting my van.Not for me, I’ve rejected my 4 week old Cali.
Incorrect. Partially.Vw don’t test o
