With relation to your 1st paragraph. I connected my Solar Panel input to the battery post clamp itself so that it is in fact the other side of the Cube Fuse.In the case of ours, the cube fuse sits on rear(3rd) battery so yes, as you say it becomes isolated from everything else, but Roger used to connect his solar charger to the rear battery so there could be a case where his solar is quite happily charging the rear battery in isolation.
If the Cube Fuse blows the Solar Panel will continue charging the rear Leisure Battery, but the Control Panel will not show the voltage increase due to the Solar Panel.
