Dr-Snickers
Kate
This looks fantastic @GrumpyGranddad. You should go in to production!
An interesting idea. I actually like ours on the right as we have a little tray that goes atop it so it can be pulled out and used as a handy little ”table” between the front and back seats.Has anyone found an easy way of moving the draw from the right to the left without buying a new runner?
I'd much prefer it on the left. So much easier to get to when the table is out.
If on the left its going to make it extremely hard to get to the gas valves?Has anyone found an easy way of moving the draw from the right to the left without buying a new runner?
Someone on here has done it so they're probably better answering but from looking at the draw in its original position then I think it would be OK.If on the left its going to make it extremely hard to get to the gas valves?
I don't see how you could get to the valves without removing the draw.Someone on here has done it so they're probably better answering but from looking at the draw in its original position then I think it would be OK.
I've just been and looked at mine. The draw on the right is low enough to switch exactly to the left and get to my valve easily.I don't see how you could get to the valves without removing the draw.
If the draw was fitted lower down to give space to get your hand in between the top of the draw & the underside of the hob then you can't open the draw when the bed is down.
We have a drawer on the left and yes, it restricts access to the gas switch a little. Not a major issue as we only need to pull the drawer out slightly for access and we only store soft items in there - tea towels etc.Someone on here has done it so they're probably better answering but from looking at the draw in its original position then I think it would be OK.
Do you have any other photos when you reduced the drawer width please? And the fixing details?We have a drawer on the left and yes, it restricts access to the gas switch a little. Not a major issue as we only need to pull the drawer out slightly for access and we only store soft items in there - tea towels etc.
OK here are some photos which might make things clearer. With the correct ‘uprights’ and ‘runners’ you wouldn’t have to modify the width of the drawer as I had to. Nor would the front of the runners be visible. It would be as per the additional drawer set that can be purchased.Hi @subthree
I can take some photos but bear in mind that my solution was a bit ‘Heath Robinson’ and based on using a slide out shelf that I wasn’t happy with. I used the fixings for the shelf but replaced the shelf itself with a modified drawer. I dismantled the drawer and reduced the width by 15mm and reassembled it. Note: The front of the drawer didn’t need reducing.
If I was starting from scratch I would fit a full sized drawer and appropriate width aluminium (or wood) uprights with the drawer rails fixed to them. Actually the ones that VW fit to the right hand drawer would probably work but you’d need to reverse them. Difficult to describe but will send a photo asap.
Thank you very much for the photos, very helpful.OK here are some photos which might make things clearer. With the correct ‘uprights’ and ‘runners’ you wouldn’t have to modify the width of the drawer as I had to. Nor would the front of the runners be visible. It would be as per the additional drawer set that can be purchased.
