nknight
We have a 2009 Cali (the one that originally suffered the earth shunt problem) which we purchased from new.
We’ve been getting some very curious battery level readings on the control panel when the auxiliary heater is turned on. The level drops alarmingly quick (which has been reported on other threads) but then when the heater is turned off, the level gradually returns to a higher level. This happened again last night. The reading went from 100% to 50% (12.5V being produced) over 5 or so minutes and then gradually back to 90% after the heater was turned off. It then showed 80% in the morning with no power drawn overnight which is only significant in that it is a long way from 50%. To complicate things some times when the heater is turned on the levels remain normal.
The batteries have in the last week received 36 hour charge on the mains. One of them is a new battery the other purchased with the one just replaced only a year ago. The dealer left a printout in the vehicle which confirmed the battery that was replaced was definitely defective and though the vehicle had been taken in because the control panel was showing rapid battery drain when the heater was being used the battery level wasn’t going down and then back up like it seems to be doing now!).
The earth shunt problem was rectified on the van (which we have had from new) 3 years ago and as the heater quickly blows warm air and there is no flickering of the lights or control panel display, this doesn’t seem to be a re-re-occurrence of that issue.
Does anyone have any suggestions about this?
We are off on hols for Easter and will have a hook up, so before returning to the dealer yet again, we won’t use the hook up until we see what is really happening with the batteries.
P.S. Our Calis is a lovely vehicle and great fun, but from an electrics perspective it has had more problems than the Alfasud Sprint I owned in the early 80s. Oh, I’ve just remembered, it’s also had the “rust” on the roof main and front panel, so it’s actually a lot like the Alfasud!
