Borris
We have just had the yellow pigtail engine management light come on which was shortly followed by reduced power limiting the vehicle to about 20mph with a rough running engine. It happened on a very busy narrow steep up hill road in Volterra, Italy. I couldn't stop there so carried on for no more than a mile and pulled into a service station.
The previous day the Ad Blue warning message had come up on the dash. It said that the range was down to 1400 miles and to refill asap. We filled up at the next available fuel station and purchased a 10litre drum of Ad Blue. As we were only a few miles from our holiday home I decided to fill the Ad Blue tank when we arrived. Unfortunately, I discovered that unlike the last drum I'd bought there was no filler pipe provided. So whilst in Volterra I had decided to buy a funnel to fill the tank. Before I had a chance to do this the problem occured. My immediate thought was Ad Blue starvation being picked up by the engine management system whilst climbing this steep hill. When I arrived at the service station I kept the engine running, bought another 10 litre drum (the other was back at our billet) and this time got the garage attendant to fill the tank. I then turned off the ignition and restarted the engine where upon there was a message that said something about an ignition fault. After turning it off and restarting again all was well, full power was restored, engine running smoothly again and no faults on dash board. Since the fault I have restarted the vehicle 4 times so the fault should still be stored. I will probably give VW Assist a call but am in two minds as the issue has now gone away. Anyway where we are staying I doubt if they could find us.
Anyone else had this issue?
From the time the Ad Blue warning message came on to the point that the EMS fault warning light illuminated was about 200 kms so there should still have been 1200 miles worth of the blue stuff in the tank.
Other possible causes:
1. Diesel Particulate Filter - I admit that I have forgotten to give it a damn good thrashing recently but it had just been driven across Europe including a couple of high alpine passes so that should havd done the trick.
2. The wrong diesel - I know you should never put bio diesel in a Cali and haven't knowingly done so. In the UK I always use premium diesel and whilst in Europe have done the same although not the same make. I have looked up the brands and grades of diesel purchased and I don't think that is the issue. However pumps are not always labelled correctly.
Any advice would be welcome.
