Pete M
Blimey £600 for a portable BBQ, yep that's pretty high end! (looks good tho).I posted on here a couple of years ago. Back then I was just about to try the Big Green Egg Mini. Well since then they launched the Big Green Egg MiniMax, a slightly bigger version, it's superb.
I now have a MiniMax and it lives in my Cali.
As with all Big Green Egg's it's just superb. Lighting to 180C is less than 15 minutes and your cooking over propped lumpwood charcoal with no nasty chemicals. Unlike the Cobb you can control the temperature, something that's super easy.
You can use it like a normal BBQ for grilling or:
1) add the ConvEGGtor to convert it into an oven
2) add a pan to use it as a hob (we do paella all the time)
3) add wood chips to turn it into a smoker
4) add the baking stone to cook proper wood fired pizzas and breads
5)...........
The Big Green Egg is used in over 35 Michelin starred restaurants in the UK alone it's that good. I'm sure no restaurant has ever used a Cobb or a Weber Go Anywhere.
It is expensive but it's streets ahead of any other BBQ.
they removed the Flavouriser Bar & turned it in to a griddle. I'm sticking with my Go Anywhere Charcoal version for now. If they bring back the flavouriser bar, then I would definitely buy one. This is why the fat is pooling at the bottom. It should land on the bar, get vapourised, then 'reflavour' the food above
