B J G
255/45/18 103V is VW factory fit. 235/55/18 104V in an SUV version is also better for load rating. Speedo will be giving close to 100% accuracy. 235/55 also cheaper than 255/45 plus greater range of brands.Hi, I need advice please, I'm changing two front tyres that have worn away on the outside rim leaving the middle nearly new. I went to three different tyre centres & got three different answers on what was the cause.
1, you have a car tyre on a van & this always happens with power steering.
2, tyres need aligning, but he would have to check first.
3, under inflation.
The tyres are correct for the van, I'm thinking under inflation & probably aligning needed.
My question is what pressures are people using?
Tyres that are worn were 235/50zr18/ 101w Davanti price £100 each.
The tyres I'm getting Michelin C/Climate same size £160 each.
I've been inflating the front 46ps & back 48 ps.
We are two medium sized adults with the usual camping gear nothing out the ordinary. The pressures on door side have not got my size tyre on so went for the nearest to my size 17.
Any advice welcomed, thanks.
