H Wiggly Woo, I think I would have an issue wiring behind the control panel (6.1) because I’m going to need to install the Power Magic Pro device (I think) as well as the camera. That’s the thing that stops the starter battery being drained if the camera is in Parking Mode. It’s a small box with a switch and it needs to be accessible after fitting.
[/QUOTE]
You mentioned in a few of your posts that you were planning to install solar. If you go for a dual battery system, it will keep the starter battery topped up (if parked with a view of the sky) despite the small load from a dash cam. Would this prevent the added complication of the Power Magic Pro. If you’re parking it under cover, can you plug in shore power, which will also maintain the batteries?
