Sp0_0k
- Messages
- 1,233
- Vehicle
- T6 Beach 4Motion
Anybody can please help with the details on brake pads for the T6 17' brakes?
My reg number isn't UK
If anybody needs the parts codes. Version with bigger 17' front ones.
Front disks 7E0 615 301 F
Rear disks 7E0 615 601 D
Front pads 7E0 698 151 C
Rear pads 7E0 698 451 B
My rear pads were done at 77,000 miles. Disks not replaced as there was no scoring. Front pads and disks replaced at same milage as there was some scoring on the back of the disks.Thread resurrect. I just ordered some brembo pads for the rear. I've done 28k and the rears have done the usual trick of wearing out before the front. What's the consensus with not bothering swapping the discs at 2016 and 28k.? They look ok through the wheels.
It all depends if the discs are badly worn. Do they have a lip on them? You will need to check the thickness with a micrometer. There will be a service thickness you shouldn’t go under.Thread resurrect. I just ordered some brembo pads for the rear. I've done 28k and the rears have done the usual trick of wearing out before the front. What's the consensus with not bothering swapping the discs at 2016 and 28k.? They look ok through the wheels.
it's 2mmThere will be a service thickness you shouldn’t go under.
That sounds rather thin for a disc!!!it's 2mm
I agree. Ha. My pads were less tan 2mm though and no warning light. The hardest part of this job is getting the pistons to return as you have to screw them in while applying force. All done now. earnt myself a pint there. £40 all in. Next time I will order the wear sensor too. Of which there is only one on the drivers sideThat sounds rather thin for a disc!!!
My rear pads were almost down to the back plate. The sensor had been skimming the disc for a while. No warning on mine at allChanged the rear pads + discs on mine today.
Surprising how thin the pads got before the warning came on.
