Build a mini Toilet CDP at home?
a892374923874
Dorset, UK
T6 Beach 150
I'm contemplating making toilet cassette emptying a little easier at home.
I have a circular plastic manhole cover against a wall outside, so I could drill a 110mm hole in it and install a 45deg bend, a drop pipe and a screw cap. If I use a 110mm coupler above the manhole then that will stop the pipe dropping through. I have a fresh water pipe near it to provide a rinse.
However I don't really want any splashes remaining in the area.
Alternatively, we're building a wet room inside, which will have a shower and a toilet, so I could tee off the toilet waste and provide a similar screw cap arrangement in the shower area so any splashes could be rinsed off with the shower. I could provide a separate rinse tap also.
Any other creative plumbing arrangements spring to mind?
Just lift the manhole cover when you want to empty the cassette.
Thanks for the comments :) . Emptying in the loo generally causes a bit of splashing, which if it was in a location that was covered by the shower would be easier to deal with. Emptying on site doesn't mean I don't have to empty again back home, although admittedly there will be less to empty.
Lifting the chamber cover requires prising it out of the frame with a tool, which I probably shouldn't do too often.
None of this is the end of the world, but I have the opportunity to do something while we're constructing a wetroom, so I thought it was worth considering.
CampervanTime
andyinluton
andyinluton
H
10K
Hotel California
H
DavidofHook
The Fockers
T
