Hi, I’ve searched but to no avail so maybe someone knows ... How much does a 17” Cascavel wheel weigh?
If my wife sees this question she will definitely divorce me!
I'm intrigued why you want to know (and risk divorce!)Hi, I’ve searched but to no avail so maybe someone knows ... How much does a 17” Cascavel wheel weigh?
Thanks Mike - sorry to hear about the puncture!When I return to UK in a couple of days and remove my punctured one from under the Cali I will weigh it.
Mike
Ok, the reason I want to know is I’m considering some TSW Bathurst 20x10 Wheels. They seem quite reasonably priced for rotary forged wheels and the 20x10.5 ones are a claimed 25lbs on the interweb. They show as compatible for a VW Transporter so I’m trying to find out the load rating. Thought if I went as lightweight as possible it all helps and was curious how they stacked up with the VW 17x7s...I'm intrigued why you want to know (and risk divorce!)
I would be careful with 10.5 wide on a CaliforniaOk, the reason I want to know is I’m considering some TSW Bathurst 20x10 Wheels. They seem quite reasonably priced for rotary forged wheels and the 20x10.5 ones are a claimed 25lbs on the interweb. They show as compatible for a VW Transporter so I’m trying to find out the load rating. Thought if I went as lightweight as possible it all helps and was curious how they stacked up with the VW 17x7s...
Hi, sorry - no intention of going 10.5 - that’s just the one they quoted as weighing 25lb so I was thinking 20x10 et35 (guessing a smidge lighter) although I’m not sure how that would work on the front with 275/35R20s and sport line springs (30mm drop)I would be careful with 10.5 wide on a California
You may not be able to open the sliding door with wheels that wide???
It will snag on the rim..
I had 10s on my first cali in 2008 and there was literally millimetres between the wheels and sliding door.
You need the make sure the offsets correct but sounds great and I'm a lover of 20s
All due respect to the people that advertise these wheelsHi, sorry - no intention of going 10.5 - that’s just the one they quoted as weighing 25lb so I was thinking 20x10 et35 (guessing a smidge lighter) although I’m not sure how that would work on the front with 275/35R20s and sport line springs (30mm drop)
Thanks - I hear what you say about sales websites. Hence checking with you guys. As far as I can tell they'll stick out (in) 18mm more on the inside (less clearance) and stick out 58mm more on the outside. I'm pretty sure that would be fine on the rear. I just don't know whether they'd rub on the front - I don't really want to do a staggered fitment. 275/35R20 is not quite as close as 255/35R20 but the latter being smaller than OEM would cause higher revs vs the 275s revving lower.... not that there's much in it so that I'd notice. I think I've got a mental block having always owned 4x4s in the past with an addiction to sticking 33" tyres on those. That didn't always work out well either.All due respect to the people that advertise these wheels
Unless they have pics of a 20" 10j rim with 35offset and 275s fitted on a California or t5 I would be weary???
I know the correct matched tyre size is 255 35 20 and the best offset for the correct look is a 45 offset.
With a 35 it will stick out 10mm more and add to that a10j rim and wider 275 I'm not sure i would go down that route??But this is Your choice buddy, do your homework before purchasing them
I had a 265 35 20 on 9 half j rims with 45 offset very slightly wider that a 255 but on a 9.5 j rim it was perfect
Mine was also b14 coilovers
Very true the ones on my Kombi above were designed for vans to carry the weightJust call TSW tech people and ask for the TUV certificate that states the load rating.
£50 says they’re not up to the job. You won’t care though will you, as long as it looks bling.
Heard back this morning. Despite being Forged they’re not up to the job so that’s that and, I do care actually. A lot. I like nice wheels but your insinuation that I’d ever fit non rated kit to my family wagon is misplaced.Just call TSW tech people and ask for the TUV certificate that states the load rating.
Looks great - the right offset makes all the difference and fills out the arches. Thanks for posting.9.5 j 20" with 265s et45
Just so you get an idea of look this was my Kombi
Good to know - thank you.There a literally hundreds of wheels out there but, for a van load rating only a few. Factor in the ones you actually like and you’re down to about three!!
I ended up having a set custom made.
You’ll prob find 45ET is optimal, 35 too much.
I run 45 with a 5 MM spacer. Fills the arches nicely.
It looks really good. Are they VW Sportline wheels?I had 20 inch wheels on my recently sold kombi, looked great but the ride was shocking. Pirelli zero 35 tyres for 10k miles, then tried 40 tyres but still a poor ride and they rubbed on full lock.
Back to 18 inch wheels now on my Beach much better ride.
