Brilliant that’s a much better charging system than my previous conversion. Great, thank youYes... Will prioritise the leisure to 100% then trickle the engine battery![]()
Ok, no problem. I won’t be using it all the time so it will definitely need charging, however I want to take care of the batteries & not run them flat, I assume that will damage them?Recommendation is to charge for 24hours every month on EHU...
Run flat will damage them yes, absolutely. But you do need to use them also. Leaving it plugged in the whole time in the garage is not great either. Even when on site EHU, you should disconnect for a few hours every few days. I am by no means an expert, just things I've picked up from the forum over the years...Ok, no problem. I won’t be using it all the time so it will definitely need charging, however I want to take care of the batteries & not run them flat, I assume that will damage them?
I use my Cali (T5 and now a T6) for going to sports tournaments and park in the available areas around the sports facilities. They are usually full weekend events from Thursday to Sunday and there is no external power available. I use the fridge the whole time as well as lighting and have never had the fridge stop on me. So 3 days is certainly achievable. I never use the heating, so can't say what that would do. I do know that the leisure batteries have to be above a certain charge for the heater to start. I have had the starter battery drain, so make sure now that the courtesy lighting is off the whole time.Anyone has experience with not-plugging the cali at all? We usually avoid campings and if we are (rarely) on one, we don't pay for the electricity anyway, as we simply don't need more than we get from the batteries.
But I have never owned a cali long-term before. If you drive consistently, is it a problem to not plug it at all and just base on the engine-charging?
I tend to turn on the max charge option quite often while driving, just so I can get a bit more juice of every drive. Not sure how much it changes, but I saw the battery voltage increases afterwards, while driving, so I guess it's more than just increasing the RPM on idle.
We go to sweden and norway in summer for 3 weeks , wild camping, only on camping once a week and even then battery only. It is no Problem if you do not stay on one place for longer than 3 days without driving.Anyone has experience with not-plugging the cali at all? We usually avoid campings and if we are (rarely) on one, we don't pay for the electricity anyway, as we simply don't need more than we get from the batteries.
So long as you drive a reasonable distance, 25-30 miles, every few days you should be fine. Especially if you also have solar panels.Anyone has experience with not-plugging the cali at all? We usually avoid campings and if we are (rarely) on one, we don't pay for the electricity anyway, as we simply don't need more than we get from the batteries.
Well, I don't have the solar power (yet). I mostly wonder if for some reasons potentially alternator wouldn't provide enough voltage/power or current stable enough to charge the batteries, in comparison to the outlet. But tbh I don't see why that would be. After all a normal car normally doesn't need any supplementary charging. Just that it has 2 batteries lessSo long as you drive a reasonable distance, 25-30 miles, every few days you should be fine. Especially if you also have solar panels.
I’ve owned our 2008 T5 since 2009 and it is used for camping and a few day trips only. It’s sat for months at a time and only gets plugged in at alternate campsites on our 2 week summer trips. The 13 years old leisure batteries still work perfectly and charge to 13v.Anyone has experience with not-plugging the cali at all? We usually avoid campings and if we are (rarely) on one, we don't pay for the electricity anyway, as we simply don't need more than we get from the batteries.
When camping, without EHU, how long do they last while powering fridge and lights?I’ve owned our 2008 T5 since 2009 and it is used for camping and a few day trips only. It’s sat for months at a time and only gets plugged in at alternate campsites on our 2 week summer trips. The 13 years old leisure batteries still work perfectly and charge to 13v.
It’s pretty reliably 10% a day. Lights and fridge only. We often do 7 days without plugging in. I recall doing 10 days once without problems but we possibly went for a couple of short drives.When camping, without EHU, how long do they last while powering fridge and lights?
