john eagle
Eaglehead
Hi can anyone please tell me if my 2017 California has a CO2 monitor built in or do I need an external one. Same question for an LPG monitor
Its a CO, Carbon Monoxide Monitor, and it doesn't have one built in.Hi can anyone please tell me if my 2017 California has a CO2 monitor built in or do I need an external one. Same question for an LPG monitor
Totally agree with this and just be glad you don’t own a canal barge with a gas cooker.I would always recommend a CO meter if you burn any fuel in an enclosed space, for about 12 quid you can't go wrong. We've had a previous van where the exhaust was faulty and leaking into the vehicle and we would not have known if not for our CO alarm.
As someone who works in the gas industry, I always get frustrated when folks are flippant about gas and make out it's not dangerous. Ultimately LPG that we use in our vans is a lot more dangerous than the gas that is piped to our houses because LPG is heavier than air.
For Natural gas, if the percentage of the air is between 5 and 15% it can ignite, any lower or higher, nothing will happen. If we come across a leak but with LPG in our industry the risk scoring pretty much doubles, because it will pool and drop down meaning there is less mixing with the air but with a chance of ignition, I think it can ignire at as little as 2% in air for propane and 1.8% for butane. Having a window helps for CO but might not necessarily help for LPG gas leaks. As it is heavier than air, if there isn't a good breeze and the gas is all pooled inside your cupboard it's going to stay there.
In an Ocean its correct it's in a locker with the required vent to let the gas drop outside the vehicle. Doesn't help if the cooker or connection starts leaking outside the locker. It has a very strong smell so you should notice it, but if you have poor sense of smell (some folk have none at all) then an detector is a must.
However as above be careful, check your pipe work annually and take care of the system and you should never experience a leak. I don't have an LPG detector but then I'm confident I would smell a leak.
I don't Disagree with fitting a CO monitor but the Gas Stove is more dangerous than the Diesel Parking heater for producing CO due to incomplete combustion. If the connection to the Burn Chamber fails then the likelihood is that the Heater will fail and not function, not so the Gas Cooker which is very dependant on adequate air flow and ventilation for correct function. Very easy to mess this up by not keeping clean or cleaning using the wrong method.Yes to carbon monoxide. If you have stripped down one of those diesel auxillary heaters you would know there is only one little rubber o ring between you and the burn chamber which on failure would happily and powerfully fill your camper with carbon monoxide whilst operating. For 12 quid I wouldn't risk it. The hob is not a major danger as far as I'm concerned, you're awake usually when using it but the espacher, webasto or even an lpg propexheater are often used while sleeping and I wouldn't allow it on in my camper without a safety backup.
The wood burning stove in our living room has better seals than diesel heaters and the law states I must have a detector for that.
P.S I don't have a Cali but dream of one (with a co detector)!
General rule of thumb we advise is if the flame is burning orange or red its burning inefficiently and thus producing CO, often see this if the burners are dirty.I don't Disagree with fitting a CO monitor but the Gas Stove is more dangerous than the Diesel Parking heater for producing CO due to incomplete combustion. If the connection to the Burn Chamber fails then the likelihood is that the Heater will fail and not function, not so the Gas Cooker which is very dependant on adequate air flow and ventilation for correct function. Very easy to mess this up by not keeping clean or cleaning using the wrong method.
I have no experience of the Gas powered Heaters.
