mccp
I'm not sure that security wheel bolts are worth the hassle. I guess if you have expensive non-standard alloys they might be attractive to thieves, but is theft of standard alloys a common problem?
I get that the spare is at risk, that's a two or three minute job to remove with a stillson. But how likely is it that someone is going to jack up your van and pinch the other wheels? If they want to keep their jack, most likely they'll need bricks to keep the van off the ground. Sounds like altogether too much forward planning to me.
I've replaced the security bolts with standard ones on my last two cars. I also think that it's a good idea to check the wheel nut torque on a new car. In the good old days, that would have been done when you had your first service and oil change after a mere 1000 miles. I've found that tyre fitters these days are pretty good at tightening the wheel nuts to the correct torque - the most recent mobile fitter I used insisted that I watched him torque all the wheel nuts and signed off a chitty to say that it had been done correctly.
