Hi
Can anyone shed any light on what this cup holder is doing behind the bench seat? Seems completely inaccessible! Am I missing something?
I've never looked but is it easy to remove the stops out of the rail? Are there any negative effects when you want to travel with the the seat further forward?If you take the stop out of the near side floor rail you can get the bench seat back far enough to actually get a cup/can in there. Still a reasonable amount of room remaining at the rear fir everyday use.
As far as my T6 is concerned, there was only 1 stop. That was on the near side rail towards the rear. If you look into the rail between the rubber strips you will see a large flat headed screw. If you undo that a little it releases a lozenge shaped piece of metal that can ‘gently’ be pulled out of the rail. It is quite fiddly but it will come out with the aid of some long nosed pliers. You can then position the bench seat as far back as you like. It frees up about 12” of floor space and has no negative effects on moving the seat further forward. We previously owned a Bilbo’s LWB and the usable floor space is now similar to that. There are some previous threads on the matter.I've never looked but is it easy to remove the stops out of the rail? Are there any negative effects when you want to travel with the the seat further forward?
For times when we don't need to carry so much and sleep upstairs it would be good to have more living room space.
Thnks for replying, Jodalo.As far as my T6 is concerned, there was only 1 stop. That was on the near side rail towards the rear. If you look into the rail between the rubber strips you will see a large flat headed screw. If you undo that a little it releases a lozenge shaped piece of metal that can ‘gently’ be pulled out of the rail. It is quite fiddly but it will come out with the aid of some long nosed pliers. You can then position the bench seat as far back as you like. It frees up about 12” of floor space and has no negative effects on moving the seat further forward. We previously owned a Bilbo’s LWB and the usable floor space is now similar to that. There are some previous threads on the matter.
Out of interest has anybody found a small bluetooth speaker that fits in this space without getting in the way of the bench being moved?
I highly recommend this.One of these also fits perfectly .....comes in many different colours and a hook to hang from.
