Borris
I have just discovered a deep score mark running part way around the inside face of one of the front 17" Thunder alloys on our nearly new Cali. Whilst I don't know for certain, I suspect that it has most likely been caused by a stone being caught in the very narrow clearance gap between the brake caliper and the wheel. I was extremely carefull removing the wheel without causing any marks in order to fit steel wheels with winter tyres. Also I doubt if they have been off before since it left the factory. Our Cali is a 180SE 4motion whith less than 2500 miles on the clock. Whilst it is not visible when the wheel is on the vehicle I am just wondering if this is a common occurrence and therefore how much more damage I can expect.
Has anyone else discovered similar damage? Also, as this shouldn't really happen, would this be a possible warrantee issue?
