mccp
It all depends on how the heater modulates its output. My guess (from casual observation) is that the heater turns on at full power until the cabin temperature reaches the thermostat set point. From that point on it will run at a lower output to maintain the temperature within a small range above and below the set point.This raises an interesting question. If I set the heater control on 7, will the van warm up (to a comfortable temperature) more quickly than if I set it on 1?
I guess that the effect would be that it seems to heat up more quickly on 7 because the heater will be running at full blast until you feel too hot, at which time you will turn the heater down.
