Planar Pete
Hi all,
I need a little help with oem trims to fit retro planar night heaters.
Fitting the heaters no problem but trying to source trims with oem vents In is a pain.
Main dealer or Tps can’t give me the part numbers for the items unless I have a Reg.
I need a Reg for t6 California with black lower trims and vent in drivers step and b pillar trim next to sliding door.
Pic attached are the trims and vents I’m needing but in black pls.
If you could be so kind to let me a Reg so I can get prices on trims required.
Many thanks
Planar Pete
Many thanks
Planar Pete
