Padraic
I fitted some Blue sea USB sockets over the weekend, I fitted one twin socket for the passenger, one twin socket for the driver, both wired to the permanent live from the fuse board and an on/off switch fitted to one of the blank switches on the dash. I might get a second rear heated window switch and use it for them just to keep the standard look.
I also fitted a twin socket in the rear from the leisure battery, I removed the Din socket or Hella socket and used that hole for a switch, then fitted the USB socket below the mains plug.
Happy enough with the install, the spare points on the fuse board allow easy connection to permanent live or live when the ignition is on. I might rotate the socket in the rear, I think it looks better withe the ports horizontal.
