AJQ
Hi, we’re booked to visit a campsite in a few weeks that only has a 3amp EHU, I’m wondering if we’ll be able to run the fridge ok on it? We have a 2019 ocean.
Many thanks
Many thanks
Just thinking that the fridge runs off 12 volts via the batteries. The EHU would re-charge the batteries via the charger. So, even if the fridge took 4 amps, should only mean that the batteries discharge slightly faster than the re-charge rate??Hi, we’re booked to visit a campsite in a few weeks that only has a 3amp EHU, I’m wondering if we’ll be able to run the fridge ok on it? We have a 2019 ocean.
Many thanks
Thank you, that’s really helpful, I’m not great at electrics but I know that plugging anything with a high wattage into the three pin socket would probably trip the EHU bollard. So it’s really helpful to understand the way the fridge takes its power won’t do that!Just thinking that the fridge runs off 12 volts via the batteries. The EHU would re-charge the batteries via the charger. So, even if the fridge took 4 amps, should only mean that the batteries discharge slightly faster than the re-charge rate??
You'll be absolutely fine running all the Camping equipment , fridge, lights, 12v sockets for charging phones etc, even the Parking Heater.Thank you, that’s really helpful, I’m not great at electrics but I know that plugging anything with a high wattage into the three pin socket would probably trip the EHU bollard. So it’s really helpful to understand the way the fridge takes its power won’t do that!
Sorry this isn’t quite right. The fridge does run off 12V via the batteries, but if the fridge draws 4A at 12V that bears no relationship with the 3A at 240V you can draw from hook up. So even with the fridge running there is ample power coming in from the mains to charge the batteries too.Just thinking that the fridge runs off 12 volts via the batteries. The EHU would re-charge the batteries via the charger. So, even if the fridge took 4 amps, should only mean that the batteries discharge slightly faster than the re-charge rate??
Ah, yes, indeed - good point!Sorry this isn’t quite right. The fridge does run off 12V via the batteries, but if the fridge draws 4A at 12V that bears no relationship with the 3A at 240V you can draw from hook up. So even with the fridge running there is ample power coming in from the mains to charge the batteries too.
As you pointed out the chance of a CB doing the job is minimal. Something like this https://itead.cc/product/sonoff-pow-elite-smart-power-meter-switch/If it is only 3A then the inrush current of the charger unit will probably pop the fuse/breaker.
The Cali looks to have electronics which limit total consumption, I’ve never measured much over 1A and didn’t notice any switch on surge. Also circuits and breakers are designed to allow for inrush current without tripping so I doubt there would be any problems using. 3A supply.If it is only 3A then the inrush current of the charger unit will probably pop the fuse/breaker.
I'm not convinced I'd know what to look for either! There were about 5 13amp EHUs at the top of the field we were in, and about 8 of the 3amp ones along the other hedges. But I wouldn't have a clue how they did it, I was just happy it all worked, and happy with the views and the sunshine.Did you notice how they were keeping it to 3A?
