andrew bazeley
- Messages
- 343
Been doing a few festivals this year, and I'm wondering if I'm getting enough "juice" to run the fridge on battery. Despite being fully charged, and setting the fridge temperature fairly high, after a little over 2 days, the display shows "50%", but this would appear to represent the total of the two batteries (the other being just for the heater), which means - in effect "0%" for the main leisure battery. Sure enough, the fridge cuts out, and even the lights begin to dim as the battery runs out.
Is this about all you should expect, or do I need to service or replace the battery?
While I'm on, 3 minor faults are niggling (early 2008 Cali): front foglights won't go off: particulate filter warning light won't go off, and turbo shutoff valve makes an embarrassing farting noise when you land and turn the engine off. Anyone else get these?
