willwander
Playing with my new Bluetooth thermometer. Doing some tests on fridge.
TLDR
- Use Level 5...or 6
- It colder at the back and bottom
- Max, between -2.8 and -0.5 degrees
- Level 6, between 5.0 and 6.7 degrees
- Level 5, between 7.9 and 9.2 degrees
- Level 4, between 5.9 and 9.9 degrees
- level 3, between 8.6 and 11.9 degrees
- level 2, between 9.5 and 13 degrees
- level 2, between 12 and 15 degrees
Test Conditions
- 2019 Ocean
- Empty fridge
- measured half way up wardrobe side fridge wall
- temperature logged every 60 seconds
Setting - MAX
Reach Temperature
It took 55 minutes of constant cooling to drop from 15 degrees (ambient) to min temperature of -2.8 degrees
Maintain Temperature
Temperature rose from -2.8 degrees to -0.5 degrees. Before dropping again to -2.8 degrees. 20 mins of temp rising, followed by 20 mins of cooling. These 20 minute cycles were maintained over the rest of the test period. (1 full day)
Here is a full graph so you get the full picture.
Level 6
Reach
approx 55 mins to reach 4.9 degrees
Maintain
Between 6.7 and 5.0 degrees, 20 minute cycles.
Level 5
Reach
approx 55 mins to reach 7.9 degrees
Maintain
Between 7.9 and 9.2 degrees, 20 minute cycles.
Level 4
Reach
approx 55 mins to reach 5.5 degrees
Maintain
Between 5.9 and 9.8 degrees, 20 minute cycles.
Level 3
Reach
approx 55 mins to reach 8.6 degrees
Maintain
Between 8.6 and 11.9 degrees, 20 minute cycles.
You can see the effect of warmer ambient temp,
it was quite warm outside to start with.
Level 2
Reach
approx 55 mins to reach 8.2 degrees
Maintain
Between 9.5 and 13 degrees, 20 minute cycles.
Level 1
Reach
approx 50 mins to reach 12 degrees
Maintain
Between 12 and 15 degrees, 20 minute cycles.
Warm up
Fridge turned off, it warms back up pretty quick. -2 degrees to 21 degrees in 4 hours.
If I can be bothered, I'll log some other fridge setting.
If I do I will add them here.
TLDR
Test Conditions
- 2019 Ocean
- Empty fridge
Setting - MAX
Reach Temperature
Level 6
Reach
Maintain
Level 5
Reach
Maintain
Level 4
Reach
Maintain
Level 3
Reach
Maintain
Level 2
Reach
Maintain
Level 1
Reach
Maintain
Warm up
