Little owl1963
Im finding that on number 5 , 2 degrees bottom and 8 degreees at top is this normal this is massive diffference !!!! ouside temp was 16 to 25 degrees .
But on another day 6 degrees at bottom and 8 degrees at top , outside temp was 6 degrees .
any research from your vehicles would be helpfull so i no what the normal difference between top and bottom should be ???
Also how often should the compressor cycle on and off ???
Been told every 20 mins ????
Hopefully welsh gas will read this ??
Thanks ian
Thanks ian
