Do you want hot air, or the set temperature?
If you want set temperature, in manual mode, the air distribution will be not as good as in auto mode, so it might feel different.
If you want hot air, put it to HI (all the way to the right), if you want to freeze your toes off, turn the knob to the left, LO. If you want a certain temperature, just put it in auto at a certain temperature. In a few minutes, it will reach set temperature. If you then think it's too cold, turn the knob to the right, if you think it's too hot, turn the knob to the left.
I have driven 2 cars before the California without airconditioning. They had a slider (Golf 2) or a turning knob with blue and red marking. Then you didn't even know what temperature it was set at. You just slid or turned the knob to the left or right untill you found a decent feeling of temperature.
Will the 22°C. in the California really be 22°C.? Possibly around that yes.
It has to be taken into account I came from a standard Ford Transit connect diseal Van , to a volkswagen cali ocean .
It did not have Auto or digital numerical control , the transit did have Air Con .
The transit van got hot within 5 mins and the position for hot air blowing was around just
over half way on temp dial .
I will start from beginning again as I did from start this thread .
Right I never used Auto on cali because was not familiar with it .so auto was off .
Found firstly cali was taking 25 mins to reach 90 degrees .
But even after 25 mins , the cab was cold an blowing on my feet was cold .
I presumed if I set digital gauge to between 22 to 24 degrees without auto on , this should blow hot air .
This was not the case , an I presumed was issue with heater .
To get hot air without Auto on have to set to 27 degrees upwards .
My mindset was if I set my room stat in my house to 22 degrees it will be hot .
Now if learnt that if want hot air to blow out by my feet .
Only way can do this with Auto off is to set dial 27 degrees and upwards , anything less than 27 will blow cold .
If want to relie on hot air blowing at 22 or 24 degrees , I have to press Auto Button or thermostatic mode .
In non Auto mode the numeric digital gauge knob does not relate to the actual temp you set it .
If all above is correct? Then my heater is working as it should .
That that part .
Next it's said that if outside temp is below 7 degrees , providing the supplementry heater is ticked within the radio console under vehicle settings, this extra heater will pre warm the engine coolant ?
I cannot test / comment on this as yet as outside temps have not dropped .
Soon as they do I will field test this .
I asked members about this setting , no one commented at all , on this TICK SETTING , only a Dutch member recently but apparently his wording read different to mine .
So we already no under normal temps , the california takes 25 mins to reach 90 degrees .so untill reaches 90 degrees we get no hot air .
Are we saying that when temps are below 7 degrees , it will not take 25 mins to reach 90 degrees ??
How long will it take , with this extra heater on ?
Soon temps drop I let you no my test results .
Please see image below.
I have posted this third time , no ref in manual a out this and no UK cali owners comment or no about this , it's in radio panel under vehicle settings
