Fridge Turning Off
T
timhutch
Milton Keynes
T6.1 Ocean 204 4 motion
I'm not sure if this has been discussed previously....
My fridge turns itself off after a few days (not sure exactly how many but probably 3/4). Is this normal? I dont leave my fridge on permanently, but I have noticed this happening whenever I do leave it on for a few days.
Do you need to keep activating the fridge periodically??
is your battery below 12volts on the lcd screen .if your not plug in to 240 volts .
Mine has gone off regularly even when the voltage is at 12.7V which is frustrating, it is being driven everyday and the battery is new. Anything above 12.4V should be considered fully charged. I think service call is due on this one...
The fridge is controlled by control panel.
All the time.
Control panel powered by starter battery under bonnet. If starter batt gets low after 3 to 4 days, fridge turns off.
I’ve researched for 3 months solid.
Look for solar cube issue
