Funny, that's just what I said...but in different words. I'm guessing you missed the meaning of my message HC. Lost in translation perhaps?@HugoFar , if you unlock the doors using the remote and open no door within a certain periode it is is normal the verhicle closes back itself .
HC, you are correct. I have/had the same feature on a Yeti and Scirocco. It is completely normal.You said "this is odd" i understood you found it "odd " meaning "strange" so i thought i explained this was meant to be "normal"![]()
HC...Hopefully this time you'll understand the angle of my post... What is 'normal'? That doors relock if not opened after unlocking with remote. What is 'odd'? That doors are still found to be unlocked hours after being unlocked with remote but not opened. Two possibilities here; that doors were not locked to begin with, or, that the auto relock programme has some how been turned off. I do hope that clears up your misunderstanding of my post.You said "this is odd" i understood you found it "odd " meaning "strange" so i thought i explained this was meant to be "normal"![]()
Well mine does too, it turns out, needed to remove the polythene cover and look further back. Doh!there is a velcro in my T6 ocean factory fitted
Just researching this issue. I’ve had maybe three occasions where I’ve come back to the van 6.1 ocean and, either the front passenger window is wide open or last week both windows driver and passenger half way open. I’m assuming it’s a key fob issue and Vw have booked it in to see if this can be deactivated? Thoughts welcome.Having had this happen on previous T5s you've just reminded me to go out and disable the remote opening of the windows on our new T6. They are a pain, squash the key fob and the van unlocks and winds down the windows, auto re-lock locks the doors after 30 seconds but the windows stay open!
Coding of this and auto re-lock is a VCDS (or similar) function.
Rod
@dayslikethis you may find that there is an option on the head unit of a 6.1 to change the 'convenience opening'. There is on my MAN TGE / Crafter. It's in the Vehicle - Settings menu.Just researching this issue. I’ve had maybe three occasions where I’ve come back to the van 6.1 ocean and, either the front passenger window is wide open or last week both windows driver and passenger half way open. I’m assuming it’s a key fob issue and Vw have booked it in to see if this can be deactivated? Thoughts welcome.
Thanks. Will check that out now@dayslikethis you may find that there is an option on the head unit of a 6.1 to change the 'convenience opening'. There is on my MAN TGE / Crafter. It's in the Vehicle - Settings menu.
Done, yes there is an option to switch it off. Thank you so much. I’ll now monitor and cancel dealerThanks. Will check that out now
Always happy to help when I can, pity the dealer couldn't tell you that over the phone!Done, yes there is an option to switch it off. Thank you so much. I’ll now monitor and cancel dealer
