I think it’s at the top of the fuse box above the relays there are 2 15amp fuses I can confirm when I get to work in the morning
That’s absolutely brilliant, I’ll pass the info on and see how we get on.I can confirm fuse s117 is at the top of the fuse box above the relays along with fuse s102. This fuse is fed by the terminal 30 power supply relay j317 in position 3 of the relay plate. Hope that helps.
