K
keacal2705
- Messages
- 110
- Location
- Hurst, Berkshire
Hi,
Can anyone help on the following.
1. When I drain my grey water, the computer display shows 1 bar even though it should be empty. I put Mr Muscle down it as it seemed slow and I thought there might be muck stopping it from clearing. However I ran the tap from a full tank of water with the waste open in an attempt to clear anything (along with mr muscle having been poured half hour earlier) but display shows empty clean water tank but waste still on one bar.
2. When you pull the bench forward it stops at a certain point even though there is more rail left. Can you make it go all the way? I realise there would be little leg room but I need to load up lots of stuff soon and the extra space would help.
3. When using the top bed, can/do people pull the silver bit across to close the hole or do they sleep with the hole open? I couldn't help but think a board is needed to rest a better light, drink (especially hot drink) or anything else.
4. Anyone got a tv set up in their Cali?
Ta
Ta
