Glove box and GPS set-up (DiY)
Andresz
Andresz
T5 HighTop
I did it myself and I find it very convenient.
The hammer is fixed to the bottom, and has the seat belt cutter and torch embedded.
The GPS cable easily goes through the upper slot of the glove box. The GPS TMC antenna works perfectly too.
Good work there similar to mine I have a double 12v socket and have run a aux cable and phone charger cable under the radio and out the dash tray :thumb
Thanks Calikev.
In my opinion the stock solution of the 12V socket in the drawer, as the only one in the front, if rather shameful for VW.
of course, it is all reversed for you in UK :smile
And you get the LHD dash the different one to the RHS Cali's?
James
Oh god solution by the way - impressed :goodone
James
James
James
Actually, I do not know, is it reversed (mirrored), or is it the same on the other side? (I mean the airbag switch placement)
