Grand California Fuse Layout
Thank you! Just tried this fix but couldn't pull the blue wire bundle out so gave up as afraid that I wouldn't be able to put it back in if I did actually get it out..
I had the same problem at first. There's a small piece of the blue plastic plug that clips in to the socket, holding it in place. You need to push and hold it horizontally when you pull the plug downwards.
Thank you for this thread and the picture! Just saved us- as currently in Pula Croatia and the step was step out. Followed the instructions and all is good now!
Thanks a lot! Now GC works again. I saved few hundreds euros. The place of the blue connector was hiiden quite well. I went under the glovebox.
Does anyone have a fuse layout specifically for a GC680.
ive included a photo for the electrical cabinet are these the only fuses on board?.
Ive got problems with the Truma gas, crash protector unit In the gas bottle cabinet
The gas is good, the bottle selector is green but the pop out button on the protector will not stay in.
When it's held in all gas supplies are good and the hob burners work okay. My first thought is possibly the fuse is blown.
Any ideas appreciated.
  • GC 600 (leisure) electrical system wiring diagrams _ VW California Owners Club.pdf
Have you used the tool ( Comes with GC )to push the pop out button back in ?
Hi
Tazgrandcalifornia -
Great info thank you. We too have step issue.
You said ‘check the step control on the dash hasn’t reset’
Where is this - what am I looking for?
Thanks Paul
