Hanging gear below lifting bed?
Chris Ratay
Chris Ratay
Overlanding South America w T6.1 Ocean 204, 4M+
Budapest
T6.1 Ocean 204 4 motion
I want to store the 2x VW window mosquito/fly screens handy, yet out of the way when not needed.
Figure a net or some bungee material screwed into the ceiling/lifting bed above the rear seat would do the trick (red area in 2nd photo). It's a brand new T6.1, so I'd prefer not to use the wrong screws...
What screws should I be using? Photos or links for visual clarity would be appreciated. Thanks.
7LA068528 Flyout T6.1 Muggenhor schuifraam - www.volkswagenshop.be - 1.jpg20230219_163514.jpg
View attachment 105117View attachment 105118
@Auberg-ine is the person to ask. See posts 1 & 100 in this thread https://vwcaliforniaclub.com/thread...purpose-t6-ocean-interior-organisation.25087/
Why not just open the roof hatch and slide them under the mattress?
Unless you are going for a very rugged / practical / overlander look, I'd be horrified to see DIY aftermarket accessories screwed to the trim of a £70k new van. I may be in a minority but suspect I'm not alone.
On the T6.1 you get the Froli springs so I think the fly screens will get mangled…;~)
Use a bag, or put on top of mattress if that's the case.
We put ours under the rear mattress, nice and flat and doesn’t get in the way. Plus, we haven’t found a need to use them yet (only used the van in the winter and the bigger issue is water leaking in the windows, so keep them taped up…!)
I agree, I wouldn’t be screwing anything into that roof lining….!
Me neither. Saw that post from Auberg-ine long time ago but thought then the same as now: nope. But, like about everything concerning your campervan: each to his own, isn’t it?
We made a bag with loop. On longer trips they hang on the back of the left front chair. On shorter trips or daily drives they hang in the closet.
Pop them on the rear boot shelf, under mattress?
Or will they fit in with the chairs ?
It’s a shame they don’t fit behind table in sliding door.
They fit ontop of the chairs. I'm hoping they don't warp :oops:
Took the idea from @Auberg-ine (above) and just wrapped 2 pieces of cord around the mattress as a test.
Stuck paper under the contact edges temporarily to prevent damage to the ceiling due to rubbing, and will come up with something nicer.
Can't see why this wouldn't work? (no drilling required)
Stow ours on the rack in the rear under the mattress.
Easy to get out when you need them ( which isn’t that often) and takes up no room..
That's exactly where I keep mine.
