Paul Grice
My neighbour in France got a bloke with a numatic drill to lower the floor of his garage..... bit extreme and spoiled my peaceful summer hols but he did get some extra clearance!
But longer so the sloping entrance might be more problematic.Even more extreme - swap it for a Marco Polo. They are not as tall.![]()
Hi Andy,I had the same problem, albeit I knew before purchase. Decided to fit air suspension as in the end it wasn’t that much more expensive than raising the garage door lintel height with a new larger double garage door.
Added bonus of variable ride heights on demand and auto-level on sites.
I've shagged a few birds in mine.still doesn't fit in the garage.Omg this is why so many people think us California owners are like caravanners. Seriously, who cares? Just get in your van, love it, drive it, admire it, have fun in it, have sex in it, do what makes you happy in it, but just get on with it. Technical s**t is so boring. Be young, get excited xxx KISS
Thanks for the warning. There should be plenty of clearance with the new door. The problem you mention is rectified after fully opening and closing again?@Chrisp , be careful with opening the roof partly and then closing it .
If the roof is not opende fully it can get out of line when you close it .
I had it on mine once , so if you have litlle clearence in the garagedoor and you lower the (partly opend ) roof and one side stays up a few inch. you might have a problem getting the Cali out ....
Ducks?I've shagged a few birds in mine.still doesn't fit in the garage.
Garages are often wider than the door aperture.If it’s that tight, how would you get in/out of the vehicle?
I've just measured mine, and with mirrors folded it is 2105 mm wide.Yes - we’ve just moved into this house with a spacious double garage, but the two (single) doors are not very wide. At some point I may rebuild the front to have a full-width door instead.
In the meantime, I might be parking it rather close to the left-hand wall, which would at least mean that having a sliding door on the driver's side would actually be an advantage!
Don't know if you've actually seen them fold but they do more of a rotating motion rather than conventional inward folding action.On a related note, can anyone tell me the width of a current Cali with the wing mirrors folded?
We're thinking of buying one, and from the standard specs I can see that it won't fit in our garage with the wing mirrors, but the outer dimension NOT including the mirrors is OK.
I suspect we'd need to keep it outside, but it would be interesting to know how much width you lose when folding them...
