Hi help needed with three pin plug
Martin11
Martin11
UK
Hi, I've recently purchased a 14 plate Cali. Yippee!!! The three pin plug behind the passenger seat doesn't seam to work. Is the fuse integral or housed in and amungst the general vehicle fuses. The socket spears to be a sealed unit.
Any help with this would be greatly appreciated. Thanks.
Martin.
The one on the side of the kitchen unit?
Presumably you are hooked up and the RCD (housed in the rear wardrobe) is on?
As GJ said the three pin plug is not an inverter - you should consider it an extension to your hookup cable :)
The two pin socket in the pilar on the passenger side is the inverter one - you can get an adapter
Ahh ok so that plug only works if I'm hooked up? Thank you. Sorry, only had the van a couple of weeks and still getting used to it. I automatically thought it would work off of the leisure battery. Thank you for your speedy responses.
I am once again a happy camper.
Thanks again.
Martin.
IMG_3005.JPG There is a mains outlet with an inverter from the 12 v battery but it's only for 150w which is tiny. It's on the same side as the one you tried and looks like my photo. Works for shavers and tooth brush chargers I suppose.
