Yep we gone down that routeYes there is. With 2 cables you get the choice of 3 lengths. 10. 15 and 25m and also if you buy a splitter you can split the power and have 240 in your awning or outside for electric cooking as well as leave the van connected.edit I meant no there isn't.
In the U.K. you rarely need more than the 10m cable. On the Continent a different matter all together. I carry both.Is there any advantage in getting a 25m length over a 10m + 15m length ( ignore cost ) ?
thanks.
Thanks all, for your input.
It's worth noting that some of the clubs (def CMHC) do not allow the joining of the multiple cables. It may depend in the wardens and if your lucky they'll let it go. We've had a couple that came and told us to disconnect them. Also had one who came to confirm the rules, but then said that once its dark they obviously wouldn't be checking.
I think that the apparent over regulated approach to safety is generated by mans abillity to circumvent any safety device/guidance due to ignorance and/or stupidity.
Darwin Awards: Evolutionary Action
Darwin Awards: Vote for the Award Nominees! The Darwin Awards commemorate the (remains of) individuals who contribute to the improvement of our gene pool by removing themselves from it. Enter this portal for stories from the Darwin Awards.darwinawards.com
I have them and it makes hook a lot easier, if the bollard is close by. Less cable, less weight when rolling it up.Is there any advantage in getting a 25m length over a 10m + 15m length ( ignore cost ) ?
thanks.
