O.K. guys and gals, I listened and now I have acted. Mark Vw2017, even after I had removed the engine and dashboard, I was left with a spider behind the headlight glass, so no marks for you.
Borris, Perfectos and Matt BW suggested vacuum via a bulb hole. The nearest bulb was the indicator.
This is what I tried:
This is how far I got, even a little closer, but the vac was not strong enough. I don't have an air line and in any case, if you look carefully you will see that as the body is in a kind of recess, I didn't think that it would blow out, so no to Big Ted's suggestion.
That leaves the suggestion Kedaw made, a bit of sticky tape on a wire.
This is what I made up:
And this is how it worked:
And this is the end result:
Yey, only half a dessicated leg left. So take a bow Kedaw. Thanks to all for their suggestions. Now, any pig owners about?
