Do you have a solar panel or can you plug in if your using it ie lights fridge etc 4/5 days. You could also turn off the isolator switch.My leisure battery is loosing its charge whilst the van is not being used. How long should it last before needing charging?
Are you sure you are switching everything off? Make sure you shut the overhead display unit off. Anything else like dash cams or Sat nave will drain the batteries. Mine lasts about a month before I recharge the batteries which is what VW recommend.My leisure battery is loosing its charge whilst the van is not being used. How long should it last before needing charging?
The OP has a Grand California so slightly different beast to a Ocean/SE.Are you sure you are switching everything off? Make sure you shut the overhead display unit off. Anything else like dash cams or Sat nave will drain the batteries. Mine lasts about a month before I recharge the batteries which is what VW recommend.
My first batteries lasted exactly 3 years and just got them replaced under warranty as they were discharging at 10% a day.
Yes I realised that after I posted. But I imagine the battery drain would be pretty much the same if everything wasn’t turned off.The OP has a Grand California so slightly different beast to a Ocean/SE.
Important thing is to turn the big red isolator off if you’re not using it for a while, this shuts down most things and reduces draw from the leisure battery to an absolute minimum.
On a similar point Just wanted to pick people’s brainsMy leisure battery is loosing its charge whilst the van is not being used. How long should it last before needing charging?
Charge the van battery once a month for 24 hours or leave a trickle charger permanently connected to the battery otherwise it'll die if not driving the van.On a similar point Just wanted to pick people’s brains
Put our VW California in our garage in Dec. Went to open it but had to use manual key as battery completely flat. Roadside Assistance (who were superb) stated battery needed replacing (covered by warranty). Any advice how to avoid this in the future? Many thanks
Anyone know if the Beach Camper also has such red isolator switch? Haven’t found it yet, but would be good to know and be able to shut most things down.The OP has a Grand California so slightly different beast to a Ocean/SE.
Many thanks - appreciate itCharge the van battery once a month for 24 hours or leave a trickle charger permanently connected to the battery otherwise it'll die if not driving the van.
The leisure batteries must also be charged once a month for 24 hours via the EHU cable plugged into the mains.
Remember, the vehicle alarm is active all that time and cold weather will degrade the performance as well. Not surprised the engine battery failed.On a similar point Just wanted to pick people’s brains
I assume this battery is a deep discharge type? in which case its not like a normal starter battery. In other words it should be able to recover from being deeply discharged? by design.My leisure battery is loosing its charge whilst the van is not being used. How long should it last before needing charging?
I would advise using the battery manufacturers website, eg Yuasa.co.uk for the most reliable information.My leisure battery is loosing its charge whilst the van is not being used. How long should it last before needing charging?
The battery manufacturer won't have a clue, its the van using it rather than the battery loosing charge. The GC does seem to consume battery power at quite a rate even when everything is switched off.I would advise using the battery manufacturers website, eg Yuasa.co.uk for the most reliable information.
One of my motorhomes had a battery isolator switch, which allowed it to stand for about14 weeks before the battery began to loose charge. Would something like that work on a modern vehicle or does it have fittings that need to draw continuous current?The GC does seem to consume battery power at quite a rate even when everything is switched off.
It does have an isolator which should help but even with the isolator not used there shouldn't be the level of consumption that I'm seeing.One of my motorhomes had a battery isolator switch, which allowed it to stand for about14 weeks before the battery began to loose charge. Would something like that work on a modern vehicle or does it have fittings that need to draw continuous current?
