How to Fix Kitchen Tap and Water Pump Problem and solution.
S9 Hotel Cali
S9 Hotel Cali
Gloucestershire
T5 SE 180
You can buy just a new microswitch ...
Brilliant. Thank you for sharing this. I immediately bought one just to have on hand. I love this forum! :thumb
Maxi-Mizer-T6
Maxi-Mizer-T6
Spain
This (and a few other threads) were of great help, as I've had 3 different issues already with the water system in the California. I've learned a few things as I fixed all of them, including replacing the water pump following the explanations on this post, so I decided to document all problems in case it helps others. Here's a first guide on how to identify which problem you are actually experiencing:
https://medium.com/@maxi-mizer/fix-vw-california-ocean-coast-kitchen-water-issues-43a19d0d893a
I hope it helps! I'll update this thread as I complete the detailed step-by-step guides (feel free to drop by that article and give me some claps and comments for motivation!)
RonB
RonB
Edinburgh
T5 SE 140
A big thank you to everyone who has contributed to both this thread and others as well, all relating to water pump problems. There are way too many to thank individually.
Suffice to say, new water pump installed successfully after following the many posts offering diagnostic advice relating to fuses, micro switch, etc.
Trickiest problem was replacing the tiny micro switch spring which inevitably pinged off whilst removing tap handle.
Thank you forum
MarkRubinstein
Brighton
New Cali owner here, having bought my 2018 california five months ago.
Water just stopped working.
* Fuse seemed ok
* looked at microswitch, looked clean but fiddled with it
* tried to see if there was any draw from the battery -nothing.
* tried to bypass the microswitch, nothing
* checked fuse again, blown.
* replaced fuse and tried tap. nothing.
* checked fuse, seemed ok
* tried bypassing the microswitch, nothing
* checked fuse, blown
* opened tank and pulled out pump and tried fiddling with the little fans at the bottom (not sure I did much)
* checked microswitch and lost the tiny bent bit getting the tap back on. Took some fiddling but got it back and tap back on, Phew!
* replaced fuse, and tried it with the top of the tank off (and so no tank level measure)
watched the display and there was no change to power - nothing at the tap
* checked fuse, still ok
* replaced the top of the tank, tried again - short power pull, no noise from the pump, fuse blown.
So i guess that the pump needs replacing.
I am a bit nervous about doing it myself. Does anyone know someone in the Brighton area (or not too far) that could replace the pump without charing a VW fortune?
Thank you
BikerGran
BikerGran
Growing old disgracefully
Dorset
T5 SE 174
If you Google 'mobile caravan servicing east sussex' it should come up with a few companies that will come to your home and fix it. I did this in Dorset and I can't remember the cost but I was surprised how little it was.
2into1
2into1
Née T4WFA. Now running 2006 LHD T5 SE 130 Manual
Glossop
T5 SE 130
If you've gotten as far as examining the pump, then replacing it with one from your local caravan shop is very easy. You've done the hard work.
ArunAlec
ArunAlec
West Sussex
T6.1 Westafalia club joker
* Fuse seemed ok
Thank you
Campersales up the road in Burgess Hill. Advertisement banner appears on this page!
Mowbotman
Mowbotman
Hawes
T5 SE 180
Very useful information, we have just had 2 days away with no water pump working , at some point over the last few months my wife mentioned something running ( i am profoundly deaf and wear a cochlear impant) so took me a while and found the tap was slightly on , causing the pump to run constantly, but not open enough to let water through although at that point there may have been no water ? But the bowl was in and nothing in that, the question is if you leave the tap open slightly and no water is coming through, and then you close glass top ( single one piece one on SE) would the glass lid shut the tap ?? As i also think that the plastic bowl in the sink when bouncing about could push the tap up and on far enough to run pump but not let water though ?? As anyone got any thought on this !! I was thinking of sticking a small piece of foam to the glass top directly above the tap lever so when the lid is down it shuts the tap !
Again any ideas on this would be greatly appreciated
ArunAlec
ArunAlec
West Sussex
I don’t think the position of the tap spout makes any difference to the flow. The tap lever operates the pump switch and mechanical flow. If the tap lever is only slightly “on” it will operate the pump but not allow water to flow.
KGCali
KGCali
Retired and still young at heart!
Essex
T5 SE 180 4Motion
As a visual aid you could always fit a flashing led to the sink that comes on whenever the pump is running.
Mowbotman
Mowbotman
Hawes
T5 SE 180
Hi I know the spout as nothing to do with its position and flow , its the lever next to it , which is being knocked by the bowl ?? , I am going back down shortly and will have a look to see if the bowl can do this, as when we use it , we would always push the lever all the way down as always , so something must be pushing slightly open !!!
ColliePops
ColliePops
Chesterfield
T6 Ocean 204
* Fuse seemed ok
Thank you
Mark - to replace then pump is very simple - you have done the hard work of all the electric checks and, of getting into the water tank and checking the veins of the pump - You have then reassembled it and tested it for the pump to start, stop and blow a fuse .
Replacing the pump is simply a case of purchasing a new one of the existing or similar make - I went for a Whale Pump (made in the UK - a little more expensive but more readily available).
You've done the electrics so no more testing there other than removing and replacing the pump fuse so you can work on the wires.
The pump simply unplugs from the water tube.
You plug in the new one.
The electrics simply wire in to the existing cables with cable connectors.
You may need to cut the ends and strip a little (just a little) but am sure you've changed a plug before and it's a easy as that.
I am the least practical person going. It took me two hours of careful step by step work.
You have managed all of the work involved in your test, except replacing the pump.
So to replace the pump is simply a repeat of the work you have already done and just taking the final step.
Why pay someone when you already have the skills to do this ?
You CAN do this.
MarkRubinstein
Brighton
Thank you, and thank you to all the posters here, for giving me the confidence and information to replace the pump. All working fine now. I particuarly want to thank post #169 for using a wrench and handle to open the top.
£25 for a new pump, £3.10 for fuses (well £6.20 as i bought a spare set) and £1.50 for chocolate box connectors.
My only concern was when i put it all back together and tap was working the display for the water tank level was flashing. I took it apart made sure the float was moving freely and put it together again and it was still flashing. Then started the engine and it is now all showing properly.
KGCali
KGCali
Essex
T5 SE 180 4Motion
Well done, you've saved a few pennies and you've learnt a lot about your Cali.
Juzza
Juzza
London
Just browsing
NoviceCaliOwner
NoviceCaliOwner
Christchurch
T5 SE 140
Close all carefully and GO................................ JOB Done!!!
Total cost : £19 + DIY Enjoyment.
Amazing post as exactly what’s happened to my cali after winter drain of the tank…. Made my own wood tool and hey presto the lid is off … just ordered the new pump off Amazon for £25 so hopefully once replaced then that will do the trick
CaliGem
CaliGem
Cheshire
T5 SE 180
I replaced my pump yesterday but it's still not working
I now onow it's not the fuse, pump or micro switch. Any more ideas welcome
