So I had my Annual MOT and Service today, on my 2014 180 Biturbo on 118745 miles, which according to some should have blown up 60,000 miles ago.
Major Service, oil , filters etc:
Brake Fluid, DSG and Haldex.
Rear Disks, severe lipping after 118k miles, and brake pads including front( my decision) although still had 50% left.
S.Hereford VW do a video survey showing underside of vehicle, tyre tread depths etc.
It showed a corrosion hole in the outer skin of exhaust ( no leak so MOT pass ). ALL the tyre treads measured between 3.1 to 4mm across all tyres ( tyres have covered about 24,000 miles ).
However, on the inside wall of the front N/S tyre there was a off-white line all around the tyre wall that looked like the tyre canvas. It would have been a MOT failure. However the garage replaced that wheel with the spare steel wheel spare and removed the tyre from the alloy wheel so it couldn’t be used. I believe if a vehicle has a spare wheel/tyre it must be legal. This one wasn’t.
The garage couldn’t explain this by general wear. The tyre treads were fine and it was just this one tyre and on the side wall, as if something had rubbed the side wall.
The only thing I can think of is that on my travels in Norway a bridge was closed and the 30km detour was a deeply rutted, very coarse gravelled, forestry road mainly used by HGVs . The road had steep ditches either side, single track and one way. I remember mostly driving with the Passenger side wheels in the rut and Drivers side on the crown as the ruts produced by the HGVs were too wide for the California.
The garage tyre man thought that was a distinct possibility as the rubber covering the side wall is relatively thin compared with the tread area.
Anyway, all sorted. MOT passed and Cali booked in for 4 new Michelin Cross Climate 2’s next week.
