Internal lights
D
Des
Hi all have had problem with flexi light and fuse has blown taking all internal lights out does any one have fuse layout legend for 2012 vehicle
Cheers des
Hi des you should find the fuse under the passenger seat. If you drop the flap under the ashtray
In the front you should find a tool to help remove the dead fuse under the passenger seat :thumb
According to the California supplement handbook 'reading lights' are fuse 18 under passenger seat. It should be a red 10 amp fuse.
Thanks Kev found 10amp blown in block of three with two other fuses rated at 30 amp
ThomasHJ
ThomasHJ
ThomasHJ
jts46
10K
Nicolas soenens
N
Trav88
caliharry
D
sidepod
sidepod
