Dodge1311
HI,
I looked through the treads but can't find a definitive answer, as most of you know i have a new Ocean on order, I wanted to use the inverter socket to plug in a battery charger, I will be adding 200 watts of solar.
My ebike bosch charger is 230V 1.5amp input and 36V 4amp output. Bosch did make a 12V DC charger for their ebikes but discontinued these some time ago. I am not overly concerned about battery drain in the van , as the ebike never gets much below 80% and i would only recharge in the day when the solar panels are doing their magic.
I can't find any detail to indicate what type of inverter is fitter as standard and if it is changeable. If it cannot cope with this type of battery charging, then my next course of action would be to use an alternate inverter using one of the DC outputs to convert from as i do in my car today but that seems a little foolish when an inverter is already fitted.
Has anyone already tried.
