Is it possible to remove the bellows to work on them?
Autumn
Autumn
Kent
Hello,
I want to put a pvc window in the front of the bellows instead of the netting.
Is it possible to remove and replace the bellows myself?
thank you
Hi yes it is possible but it’s painfully slow work to slowly peal out the rubber edge without ripping the stitching if you are going to reuse them. You will also need to mark up the four corners and the middle front and back to re aline when Reinstalling. You will also need a small 5-6mm wide roller to refit the rubber back into the grove correctly.
ooh, sounds a bit tricky, I will have a think about a different way of covering the netting with a window, me thinks.
Thank you
