ISOFIX fixings
JRD
JRD
Wigan
T6 Beach 150
I have a 2017 Ocean. I have just noticed that the bench seat only appears to have one set of isofix fitting in the middle of the seat. Also if you fitted one the adult seat belts will be covered. Does this mean that if you fit an isofix car seat nobody else can use the rear seat at the same time?
Ryemslie
Ryemslie
Aberdeen
T5 SE 140
There are two in there you just have to find them. The inner ones are easy to locate, the outer ones are a little harder! If you push your finger through just inside of the seatbelts you feel a bar. The the left of that if you feel upwards you’ll feel the other isofix anchor. They’re a bit of a chew to fix onto the first few times but you soon get used to it.
sensisuperstar
sensisuperstar
Wibble
Yorkshire
T6 Ocean 204
Have a look from the boot and you’ll see the four isofix points, and the two lower tether points. They aren’t the easiest of vehicles to fit baby seats, as I found out this weekend :mad:
Cowbridge
T5 SE 180 4Motion
Pull the seat forward and then recline the back rest. Easier to access them then. One set each side.
JRD
JRD
Wigan
T6 Beach 150
Thanks everyone I will have another look in the morning.
JRD
JRD
Wigan
T6 Beach 150
I have found them. Again thanks for the replies.
