stephen watson
I've received lots of advice from members but haven't been able to give much back so far, so thought I would share this. I have a new Ocean with T6 bike rack and wanted to keep the bikes below 2m for travel in France: getting under barriers, fuel consumption etc etc.
I managed to buy at a reasonable price san remo bike racks, one for a wheel and one for a fork mounted frame (per bike):
https://www.athleteshop.co.uk/elite-bicycle-carrier-new-san-remo-universal-without-rail
https://www.athleteshop.co.uk/elite-extra-holder-porta-ruata-80-for-dismounted-front-wheel
http://www.ikea.com/gb/en/products/...ds/legitim-chopping-board-white-art-90202268/
By lowering the saddle and mounting at the fork, you can keep the frame below roof height. You could just carry the front wheel in the van or tie it to the bike, but I decided to go the full hog and buy 2 wheel holders that will sit side by side on one rail of the T6 rack. This way I can carry 2 bikes, with wheels mounted separately, using 3 rails of the rack.
You don't need all the san remo pieces you buy. I was wondering how to attach the san remo bits to the T6 bike rack and think I had a brainwave (well maybe not if it falls to bits after use but it looks like it will be good)! I discovered an IKEA chopping board is the perfect fit to slide into the T6 rack after removing the end cap. It's very easy to cut to size and drill holes through, but I hope strong and rigid enough to do the job. If you wanted a Rolls Royce solution I guess you could get some aluminum pieces made up. Finally I had to buy some stainless steel bolts to bolt the san remo bits to the ikea plastic and then simply slide them into the T6 rack. One thing I like is that you don't need to drill or cut the T6 rack and it's adjustable in that you can slide the ikea bit along the rail.
There will be other solutions I'm sure and cheaper ways as well.
