Local help with leaking side window
TimR
TimR
T5 SE 180
Hi, T5.1 SE 2011 here with leak to kitchen side window.
Worked fine until I got some leaves trapped in the mechanism and then the problems started. I have tried cleaning it out and wiping clear the rubber seal. Both drain holes are not functioning with water coming inside from both after doing the syringe test on the front one and putting water into the area where the hidden drainage hole is.
I don't have the expertise to go any further. Does any other member know of anyone in the North West England (or North East) area who could possibly help?
Cheers
Also does anyone know the code for a replacement frame and window if it comes to that? Mine is greenish tint but i have just spent an hour going through all the vehicle data codes in my service book and windows are not listed!
How far up the north west? I have used a company in Carlisle called van glass, you could try them
T4Life at Goosnargh, near Preston. Good guys.
Thanks will check them out. Do you know if they know about the California leaky windows?
Yes they are familiar with them as they are fitted on other transporters too. I would give Toby a call there, very helpful chatty guy. Proper VW enthusuasts.
post number 10 op had theirs fixed at Hadwins, South Cumbria.
Sorry Penrith area so yes Carlisle would work. Did they deal with your leaking window or was it something different?
They installed two windows in the back of a caddy maxi, and the work was of good quality and price, they should be able sort out your problem, they are on kingmoor behind gates tyres
