DM
Nightmare scenario on Friday driving to Cornwall. I got a flat tyre but when I went to change the wheel I discovered that the locking wheel bolt adapter had failed. Half of the 'key' in the adapter had sheared off so the adapter would not engage effectively on the bolt.
Fortunately Green Flag were able to able to dispatch a technician from Highfield garage near Okehampton who was able to remove the locking wheel bolt, change the wheel and even throw in a standard replacement bolt for free. No complaints there.
But I didn't want to risk getting caught out again on the way home so contacted the local VW dealer at Indian Queens to find out whether they could supply a replacement adapter or at least remove the other locking bolts. The service there was less impressive. They couldn't tell me whether replacements are available and wouldn't even 'take a look' until 5 days later. MJB Tyres in Hayles came to the rescue whipping the other nuts off in no time for a very reasonable charge (£25).
Its a sad reflection of VW that the two independent garages I dealt with provided a way better service than the main dealer.
But that's not the point of this post. I really wanted to ask whether others think that locking wheel bolts are worth the hassle. Both the roadside technician and the tyre depot reckoned that they're not worth the bother any more. Neither of them could recall an incident where someone had had a vehicle jacked up to nick alloy wheels and thought it highly unlikely unless the wheels were very top spec. And both said they regularly have to remove locking nuts / bolts (usually because the adapter is lost rather than damaged). I have the standard factory fit 17 alloys so should I bother to get a new set of locking bolts or not?
