sidepod
- Messages
- 6,985
- Vehicle
- T4 PopTop
Looks good, when I get a Cali I'm hoping to do a similar upgrade. Just wondering does the position of the unit allow for easy viewing while driving?
It's not too bad. It obvs would be better more central. It's big enough to see.Looks good, when I get a Cali I'm hoping to do a similar upgrade. Just wondering does the position of the unit allow for easy viewing while driving?
This model has a split screen option so you can have the satnav or music closest to you.
It's only LHD imports that have sufficient space for a double DIN unit. U.K. models have a steering column structure in the way.
I understood it's not all LHD imports....as I was told mine has the cross member. I thought age had something to do with it?? Maybe I should check!It's only LHD imports that have sufficient space for a double DIN unit.
Has yours a double or single din fitted at the factory? I had thought up until now that all Cali's fitted with a single din had a crossmember and the ones with a double din didn't.I understood it's not all LHD imports....as I was told mine has the cross member. I thought age had something to do with it?? Maybe I should check!
Mine's a single din... A Gamma from memory. Not many Cali's here can play cassettesHas yours a double or single din fitted at the factory? I had thought up until now that all Cali's fitted with a single din had a crossmember and the ones with a double din didn't.
Hi Sidepod, I’m new and have a 2002 California Westfalia with Sat Nav, here is a picture, just following this old thread Sat Nav upgrade I too have the same problem I have radio Sat Nav CD 6 Changer integration in the main unit, did you find a solution to the problem?Chaps,
The new bus has the MFD1 Nav/TV unit (2003).
I've done some preliminary research into converting this head unit to take iPhone 6 input and reverse camera input.
I think it's a non starter after iPhone 4 plus the single input won't allow reverse switch activation of the camera.
Probably the double DIN head unit needs changing.
Any experience here?
P.
