Calimark
Does anyone have any experience in fitting the California front and rear mudflaps..I was just wondering whether this is an easy job or whether I will need to get the garage to fit them.
That would be a freudian slip that then!Omg. Gutted had mud flaps fitted by VW and they have drilled into the bummer to fit them. Not happy at all
To fit them retrospectively you have to drill into the bumper.
Not an issue unless you plan to remove them down the line for some reason?
I will try to find out. Personally I prefer the factory fitted flaps as they look better. Also upon reflection, depending on how they are fitted inside the rear bumper they are probably more secure. I suspect the aftermarket ones are just held in place by self tapping screws. However if the cost of retro fitting the factory flaps is too high then I will have to accept the after market jobs.The original VW front and rear mud flaps fitted to my 2010 VW Multivan 4 Motion are still going well and still firmly fixed but the rear of the Multivan rides about 40-50mm higher than the Cali probably due to lighter weight, so less likely to get knocked off. If the Multivan had a full 7 people with luggage load,then the ride height is probably the same as the Cali. But we very rarely do this.
I'm very interested to know from your Dealer Borris if they find any locator points printed onto or moulded into the inside of the rear bumper. If they are in the plastic moulding then a correct drilling pattern will be far more likely than a guessed one. Appears there are 3 side bumper holes to drill,and the two underside fixing points. One of which seems to require the addition of the supplied steel angle plate.
They look good, did you have to drill any holes?After-sale Mud Flaps
I fitted these mud flaps recently. I think they look good, are very easy to fit, have stayed on so far and are relatively cheap!
https://urbancraftuk.wordpress.com/2016/04/18/vw-california-mud-flaps/
