Yeah no EHU so will need to fit something, probably under the bonnet as per my old vanEHU was not standard on early Beach model, if it doesn’t have an obvious EHU flap on thd Near side rear quarter it likely doesn’t have EHU
You can retro fit easily and in less obvious places ( under bonnet, rear quarter, under rear bumper etc )
Post a photo of the near side if you need confirmation, if no EHU the Leisure battery charges from the alternator when driving.
Solar panels will assist in charging LB
There is a really neat solution that replaces the front grill , the EHU is plugged into the badge (badge fold out on a hinge)Yeah no EHU so will need to fit something, probably under the bonnet as per my old van
Yeah but the hardest to complete, mains near the radiator in the engine bay through the bulkhead past the passenger seat to find itself somewhere near the leisure battery to power a charger. The RCD needs putting as close to the inlet as possible, arctic 2.5 mm flex is best, but in engine bay it should be armoured, there is a reason VW put it down the side that doesn't open, short run easy install.behind the badge looks the coolest
My ehu is located under the rear bumper on the near side. This was done early in its life, as it was an ex hire van.
