Loz
No I have pulled the tabs back and tried lifting this up but does not move. If I pull harder the whole fuse unit moves slightly.
@LozAre you able to get to the connections under here from under the front of the seat?
What was the outcome?@Loz
I have had another go at this black box. I can pull it it of its holder but it seems to be a sealed unit, with limited movement so cannot check underneath. It does seem to be very hot to touch.
Do these cables drain the battery if plugged in even if no phone is attached?any telephone charge cables etc plugged in anywhere?
NoDo these cables drain the battery if plugged in even if no phone is attached?
Any USB charger plugged into a 12v socket will drain the Leisure or Engine battery, whichever battery powers them, whether there is a lead plugged in or not, UNLESS the USB charger can be switched OFF or the power supply is Ignition ON only.
The power draw is tiny, so not worth worrying about.Any USB charger plugged into a 12v socket will drain the Leisure or Engine battery, whichever battery powers them, whether there is a lead plugged in or not, UNLESS the USB charger can be switched OFF or the power supply is Ignition ON only.
Some newer built in USB sockets are only switched on when a cable is plugged in.
True, but more than capable of flattening a battery depending on its status and how long it is left without driving or plugging into EHU.The power draw is tiny, so not worth worrying about.
